h0gr1der
All,
Reading the threads from 2012 to now, see a trend of continuously lowering belt tensions for all models. Most people reference a TST from 2015(? I think), but I can't seem to find anything specific to the models after 2015. I don't think the driveline has changed, so it may be the same.
I'm chasing vibration. My 2018 RTL came from the dealer with over 220 lbs of Krikit tension with the wheel lifted, and had a teeth rattling vibration about the 70 MPH mark. Lowered it to around 160 lbs, seemed to help. Replaced the rear wheel, been chasing the vibration unicorn ever since. Seems like the lower I go, the better it gets.
So the question is, what is the lowest published number you can use? I've seen as low as 530N/119 Lbs with the tolerance used all up. Is that a reasonable number to use with it set in the air? I know BRP says absolutely no damage in occurring, but having my share of Harley miles I can assure you vibration is bad, it brakes stuff.
