JT's bar mount and wiring power help.
JP58
I have the JT bar mount. I want to install the 12v plus usb. Two things. How do I run the wire's from top of dash to the battery. I also have and auxiliary fuse block with both hot and accessory. I want to mount in Frunk. Looking for place to connect accessory wire key on only wire. 2015 RT-S. Thanks.
I ran mine through the hole for the windshield support arm. I mounted my FZ1 under the left black cover under the frunk lid. Lots of room there. Grabbed switched power from the separate wire where my left gauge used to be. All works great
Sent from my VS990 using Tapatalk
Not a lot
What do I need to take apart to feed wire down to battery or my fuse block
You need to remove the mirrors and lower wind wings. Then the two black covers one on either side of the frunk at the top. Then the two small lower covers can be removed and lastly both sides upper covers. Depending on where you locate your Fuze Block you might have to remove the cover over the head lights. Lastly it helps to remove the cover surrounding the gauges. I have done this numerous times so it only takes me about 10 to fifteen minutes to remove all of this or reinstall it. Good Luck!
