I'm trying to install a GPS on my 2013 RTS SM5. It already had a connector on the handlebar mount that fit my Garmin GPS but it was dead. I removed the wiring and it was directly connected to the battery. I have the new wiring kit but I do not want to connect it directly to the battery because it has a power light on the transfromer and it will drain the battery. Is there a way to install the wiring so it will only power on when the key is turned on? I've seen several videos on GPS installs where there is an accessory wire under the seat. I could not locate that wire. Any help is greatly appreciated.
Best Regards,
Tim
Best Regards,
Tim
