2018 RTL GPS circuit. Blew a fuse? Can anyone give me a pointer towards which one?
If you were using the connection on the right side, then that power comes directly from the radio power supply. Thus, it is very limited and not able to supply your needs. If your bike does not have a 12v power plug already installed up front, then the ends of that accessory power harness should have these connectors on them. See pic. You can then just buy the other half of it and push the connectors together. Things have been hot up here on and off but not like you folks.
Correct me if I'm wrong, but that looks like a garden variety spade connector with a 90?
OK, those GVSCers are on the same circuit as the GPS power on the left side behind the fuel tank. You will notice it says sw power or 12V always on along right side. That would be F6 SW or F7 12V always,
