DickB
This is Pedal Commander's definition of throttle response:Quote: The Pedal Commander increases (or decreases) the sensitivity of the twist grip, but does not improve throttle response. If you improve the sensitivity you improve throttle response. There is a big difference using one and not using one. No added hp, but delivering the hp quicker to you. Bottom line if you want one buy it.
David
“… throttle response is actually a measurement of the time taken for a change in power output”.
Let's take this step-by-step:
1. Ryker has a throttle-by-wire system.
2. The twist grip sends a signal to the ECU to indicate its position.
3. The throttle is operated by a servo motor in the throttle body.
4. The ECU controls the throttle servo motor.
5. The twist grip signal to the ECU is an analog voltage, about 0V at no twist and 1V at full twist.
6. Pedal Commander plugs in between the twist grip and the ECU.
7. Pedal Commander alters the analog voltage from the twist grip to the ECU as per a graph published by Pedal Commander.
8. At 30% twist, the voltage out of the twist grip is .3V, while the Pedal Commander voltage to the ECU is .5V (in City mode).
9. At 50% twist, the voltage out of the twist grip is .5V, while the Pedal Commander voltage to the ECU is .7V (in City mode).
10. 50% twist without Pedal Commander delivers the same analog voltage to the ECU as 30% twist with Pedal Commander, which is .5V.
11. 100% twist in either case delivers 1V to the ECU.
12. The ECU is not altered by Pedal Commander.
13. Given the same voltage input to the ECU, the ECU is going to set the throttle position in the same manner.
(Please point out if you believe that any of these statements is not true.)
If I twist the grip 100% with or without Pedal Commander, per pedal Commander's own chart the signal to the ECU is the same, therefore the throttle is opened the same, in the same amount of time. How is that delivering the hp quicker?
