Yes. In reality though I would say half right. Less movement of your wrist, but not
significantly faster. Attached is an oscilloscope trace of the Ryker twist grip signal with my twisting fully open as fast as I can. Note the time scale is 20mS per division. So I got to full twist in 80 MS - less than 1/10 second. The right vertical line intersection with the red trace shows the signal level that the ECU would see with Pedal Commander with the grip twisted to the same amount (30%) as the left vertical line. In other words, to get the same signal level to the ECU as Pedal Commander would, but without one, I would need to add the time to twist from 30% to 50%, which is the amount of time between the vertical lines - 20 mS, or 0.02 seconds. So yes, that is faster, but I question the significance of that short of a time reduction.
But notice from Pedal Commander's graph, their ramp is actually
slower at the upper end. So the time to twist to 100% signal is exactly the same in both cases, the exact same time.
Except for Pedal Commander's Eco mode, Pedal Commander starts with a high rate of sensitivity at low RPMs, and less sensitivity at high RPMS. For best
control of wheelspin, that is exactly opposite of what you want. The Mercedes '99 SLK ECU design enhances control. Up to about 1/2 pedal travel, the sensitivity is low. Above that, the sensitivity is high. You don't loose an ounce of power, or any significant time to get to it, but you gain control. I don't know the Ryker ECU's transfer function, but I would not be surprised if it does something similar in Normal mode. We know that it reduces sensitivity in ECO mode:
The ECO (fuel economy mode) setting reduces fuel consumption by limiting throttle response and maximum throttle opening to maintain an optimal cruising setting.
I don't know the Ryker ECU's transfer function, but I would not be surprised if it does something similar as Mercedes in Normal mode. We know that it reduces sensitivity in ECO mode:
"The ECO (fuel economy mode) setting reduces fuel consumption by limiting throttle response and maximum throttle opening to maintain an optimal cruising setting."
In my mind, Pedal Commander Sport+ mode is ridiculous - 80+% twist grip signal at 10% twist. How can you modulate wheelspin with that? But that statement is just my opinion.
