Bob Denman
But :shocked:; those are the BEST days to go for a ride... for ice cream!! :2thumbs:I am retired and don't really see a reason to ride in those high temp days...
Bob, now you are beginning to sound like a Goldwing rider...heading to the nearest Dairy Queen.But :shocked:; those are the BEST days to go for a ride... for ice cream!! :2thumbs:
Last, but my favorite. Sell it!
Did you thank the poster because this would be the ultimate "fix" to the "hot foot" problem no............? :dontknow:
Personally I think the whole problem is just karma coming around. We have to listen to all you "hot" spot dwellers make fun of us poor northern folks because of our winters and not being able to ride all year.
Sounds to me like you all can't ride all year either? :shocked: :shocked:
Personally I think the whole problem is just karma coming around. We have to listen to all you "hot" spot dwellers make fun of us poor northern folks because of our winters and not being able to ride all year. Sounds to me like you all can't ride all year either? :shocked: :shocked:
Nope. Some of us lack the intelligence required to give up!
No 86 degrees is not hot, except in the direct sunlight, it gets warm. Point is that the radiator exhaust hole, in similar degree days was like a blow torch....now it is not.... Also, by me modifying my stock seat and moving me way back, I get better leg position on the RT floorboards. My right and left feet are not pushed forward at all...I can ride my right foot in the back of the floor board and even backwards on the passenger floor boards.
well, I might have spoken too soon. I posted the comment quoted above earlier in this thread. Today, took the 2013 RT Limited on a 200 mile ride. Hottest temps in the sun were about 91. Did not have any trouble with heat until I got almost home at about 2:30 pm. After I filled up with gas and started to leave the gas station, the spyder showed overheated temp and indicated it had gone into limp mode home. I rev'd the engine a little and it dropped out of the limp mode and the temp gauge dropped back to mid-range. Was able to continue home as normal. Is this typical or is it due to the block off plate being installed on the newer RT's?
Do you recall if your fan was running or not?
don't think it was, as I was shocked and did not pay attention to the sound of the fan. After I rev'd the engine I know the fan was on and the gauge dropped to mid range.
Dang, it only has 500 miles on it. I mean, a 30k dollar machine should not require that much maintenanceWould be smart to get your owners manual out and check your coolant level, then keep and ear out for when the fan does and doesn’t run. Then subconsciously you'll always be aware of it. If it does not run......check fuses and relays.
I have had this happen twice already. Fan was running both times. It happened after a short stop (less than 10 minutes). Coolant level is good. BTW I have ~2500 miles.
And, the only thing that will get it to 100,000 miles is you and your technician. The more you know about it the better you can communicate with him. These aren't what you may be used to. Get in and go. They're more like a really good woman. Ya gotta pay attention to them. If ya know what I mean.
Well, not to be abrasive and certainly not intending to, but using that reasoning for driving a brand new machine is on the far side of absurdity. One should be able to drive it without burning your feet up, having limp home mode indicators coming and overheating...BRP knows of the issues and still does not correct them. I like the concept of the spyder, but it is still weak in achieving the "exceptionally reliable" rating. Secondly, they should have some program to ensure that dealers live up to their franchise standards...people that drive touring machines need to except the same level of service in Florida as they do in NC, etc....
