ulflyer
????? The cat sits on the left side of the RT, so either you are talking about your other right foot, or your heat source is probably not what you think it is. Remember that when you block the radiator outlets, you just push the heat out elsewhere...in this case under the right side. I suspect that is the source of the heat you continue to feel...it has jst move a bit farther back and down.
OMG, now I feel really stupid! I did enlarge the underneath opening a little the other day and likely that caused a diff flow of hot air. :banghead: Gonna have to take a new look at right side to see if theres something I can to do to redirect the flow downward.
Thanks Scotty.
Scotty....just came in from jacking up the RT and the Cat is exactly in the middle; however, the right side pipe coming out of it is closer to the outside than the left side and not as well protected with the Spyderpop shields and may the source of my heat issue. As a tempo measure I wrapped some gasket material used for mufflers around it to make a shield and wired it on. If the above gives me relief, I'll get some muffler wrap for a more permanent fix.
