flamingobabe
...in the pink (Girls On Spyders)
Today I had to run errands...about 90 degrees F so I took the 2013 ST-L that has all the heat issues....I had 160 miles showing on a tank of gas....wow...when the ST is running good I get 36mpg...great.....gas light came on...pulled in to get gas....knew I was going home in about an hour so only put 2 gallons in ....hate to put the bike up with full tank of gas....turned key on...."High Temp" light is showing...start engine...then across the screen....High Temps...Limp Mode....I was at the pump of gas station and decided to leave ...did not want to catch fire at the pump....bike hesitant to go....then everything on the screen went away...I still had 4 bars with no color...so technically the engine should not be high temps.... so I just went home.......I need for this bike to be fixed...so I'm not afraid to ride it...I'm so tired of complaining.....:banghead::helpsmilie::gaah::bdh:
Thanks....think I'll go cry....remember...I a girl
