Help identifying these plugs?
MrSchaefer
Under the front corner panels - my guess is fog lights? But there are two of them.. one with two wires (orange/green) and one with three wires (black/gray w orange stripe/gray w green stripe)
Sorry don’t have bike here to look at:sour: do have the fog light installation instructions ,that looks like the 3wire plug (with dust cap inserts) are for light on either side. That still requires adapter before connects to bulb. Does not show anything about the 2wire connectors.
I did a lot of DIY on my past 2013 STS. I used the factory wires, when ever possible, with my switches and devices.
Compatible switches are available from Amazon.
There should be a three wire connector on each side of the bike.
The three wires are for fog lights. You only use 2 of the 3 conductors to run the lights. Selecting which 2 of the 3 determines how the fog lights operate.
View attachment Fog light install.docx
ROADSTER KIT - Fog Lights Part number (SKU) : 219400614
The two wire connector should only be on the right side of the bike.
Its for connecting heated grips.
View attachment Heated Grip install.docx
ROADSTER KIT - Driver Heated Grips Part number (SKU) : 219400356
