Just a heads up.. monster fuel next month is coming out with a hand programmer so you'll be able to switch between stock tune and the different stages...so you can have a tune under warranty...you need to take your Spyder to the dealer?....remove the tune..when the warranty work is done..hook up the programmer..put the tune back in.. nobody knows your business...go to monsters webpage...it's there.
Any updates on this yet??
I got mine back and installed yesterday. I went for a ryde and it ran good but not as fast as I expected. Not sure if it needs time to adjust or I need to remove the 1 baffle that is on the front end of my RLS cat delete. I don't really want it any louder.
Just a little Survey for those that have had the ECU Flashed on their Spyder. Could you provide how long it is that you have being riding with the upgrade and what your results have being, etc.
I must be the only one not noticing a difference between stock and Stage 1 and its been a year now, i first thought maybe it was a case of getting my ecu back without the flash but I lost my eco mode and I reved it higher than stock rpm limit so i know it got flashed. I even did a comparison with my cousin who is running stock and he actually pulls ahead all the time, he is 20lbs lighter but still.
I'm NOT sure which F3 models have the 89 T rear sprockets...But if yours has the 79 T sprocket and your cousin has the 89 T sprocket you'll NEVER keep up...
tell us more about your exhaust...is it factory or cat delete...if its a cat delete, what brand, and does it have a baffle?...give us more info.
Change out the factory exhaust..the tune needs to breathe...or at least remove the cat...I suggest the RLS cat delete with NO baffle..Stock exhaust.
