gauge lights on
rock
i got 2 warning lites on my rts that im not sure what they are...1 is where the blinking parking brake light is and the other is a blinking light in the tripometer..i checked the book and it looks like some kind of brake warning..i checked the brake fluid and all is well..the lites blink the whole time i am riding...is this a problem or is there a procedure i have to go through to turn them off...
Depends..!
not to clear but there are several brake failure reasons. If you ryde with your foot on the brake this will happen. If the park is off track etc you can get these warnings. You can pull codes that will help pin point. Ryding with these on may cause you to go into a limp mode or shut down. Need to get a better handle on it. The free app from Roger Rattigan is free and will show you how to get the codes and give you solutions..spyder codes for androids and my spyder for I phones..good luck..if you get the codes let us know..:thumbup:
To pull the codes on an RT or ST push the Mode, Set and turn signal cancel buttons at the same time. If the screen is blank you have no active codes.
gauge lites on
i got the fault codes...C1282 and P0175...uploaded the app u suggested and had good answers...c1282 is low pressure detected .. possible leak in brake fluid but fluids are full..and p0175 is a fuel issue..system to rich bank 2..injection and fuel supply system..check fuel pressure regulator..
