Gates Krikit II Belt Tension Gauges
Hi All,
The Krikit II I sourced from NAPA has a ridge on the lower bottom edge for holding against the edge of the belt.
With the 2011 RT drive belt (vs. a serpentine belt the gauge was designed for), using the Krikit on the edge causes the belt to twist when taking a reading (about 160 with wheel on the ground).
Placing the gauge in the center of the belt, which does not allow the gauge to sit parallel to the belt, does not twist the belt when taking a reading, but typically reads 170-180.
What is the proper method?
Thanks!
Joe
Is this what you have and what you're doing?
https://youtu.be/z11wfc-0-hY
