Factory Looking Garage Door Opener Install
I wanted to add a garage door opener to my bike that looked factory and did not involve cutting or splicing. After adding the factory fog lights and heated hand grips, my 2013 STS had one empty spot where other models have the switch for the suspension control. I decided to use that switch location for a garage door opener. This is very much like the kit from Mo-Door, but the switch in their kit does no have a legend and is not lit like the factory switches. This mod can be used with their kit or with your own garage door opener.
The switches used are Carling Contura V switches. You can not purchase one in single quantities with the proper configuration of positions, lighting and lens. Because they are modular (the switch base, top and actuator are all interchangeable) you can assemble exactly what you need. It required purchasing the following (more detail and part number to come):
Switch Body ($13.90)
Switch Actuator ($0.98)
Switch Connector Body ($0.89)
Switch Connector Terminals ($0.31/ea)
Spyder Switch (Any with the proper amber or blue lighting will work)
I simply soldered wires to a garage door opener I had on hand and attached them to the proper spots on the switch. I then added wires to extend the illumination terminals to the illumination contacts on the unused suspension switch connector on the bike. You could also de-pin them from the bike connector and slide them in to the connector I purchased for the new switch. I then used a label printer to create a sticker (black print on clear) to put over the lens for the legend (icon).
Operation
Pressing the switch up opens/closes garage door 1. Pressing the switch down opens/closes garage door 2. Switch automatically springs back to the center position. The switch is lit whenever the ignition is on (like the other switches). Looks about as factory as you can get without a custom run of switches with two lenses and a better legend/icon.
- Carling part number VLD2GHNB-AAC00-000
- On - Off - On (Both on positions momentary)
- Carling part number VVA9C00-000
- Single Clear Lens (Dual Clear Lens only available as a large custom production run)
- Carling part number VC1-01
- Tyco part number 60295-2
- Cannibalized for the top half with the LED. The amber LEDs used in the can-am switches (on the ST) are different than the readily available amber lit Carling switches.
Operation
