In view of the failures of front pullies was just thinking. Who has pulled their pulley and either put spline grease or locktite to stave off future failures and what did you use? And who suffered a failure because of a dry spline?
I find this issue interesting …. to the best of my knowledge … this was never a problem with the RT …. Why is it an issue with the F-3 ???? ….. Could this be similar to the DESS Fiasco ….. Not a problem until some engineer decided it needed Fixing …. NOW there is a problem … Is this a Canadian thing ????? ………...….good luck …. Mikehyea:
Does that mean what it sounds like, ThatRTL SE5 just don't have the problem. Except for some normal wear an tear.
This problem started in 2008 on the GS/RS models. The BRP engineers issued a TSB stating that the cause of the failure was 'insufficient clamping force' on the pulley - meaning that the bolt wasn't done up properly tight at the factory, so they increased the torque spec and told dealers to mark a X on the head of the bolt when it had been retorqued. That just about solved the problem except for folks whose trikes never got the retorque to the higher spec because they never got back to a dealer, or the dealer was ignorant. :bdh:
And don't pick on my Canadian friends or.....or..........or I'll say something nice about Donny Trump. :yikes:
There are several reports of this failure on the RT1330 that I've read hereabouts. :cheers:
PMK are you saying that your splines were lubricated from the factory?
I'm reading this thread and looking at the links, I'm mystified by the responses, the red dust is rust, the splines aren't wearing out, they're rusting out! For rust to form, water must be penetrating the splines therefore there must be space at the bolt/washer and/or space at the rear pulley flange.
Filling the spline clearance with moly grease is a good idea, filling it with a water resistant grease might be a better idea.
Ideally, in use there should be no movement between the splined shaft and the pulley so molybdenum to prevent wear shouldn't be necessary.
The fix is to catch it before it starts and be sure the washer is good, there's no bruising on the pulley faces, plenty of water resistant grease to fill the splines and washer face to keep out the water, locktite on the thread and the bolt tightened properly so there is no movement of the pulley. With no water ingress and no movement, should be good to go! :thumbup:
You Know I've ridden two wheel motorcycles for 50+ years...ON almost all my off road bikes I changed the front chain drive sprockets to a smaller size for lower gearing for off road riding...From what I can remember most of these sprockets fit loosely on the transmission output shaft and were held on WITH a large E clip...I rode in every tube of mud hole that existed...I had chain and sprockets wear out from mud, dirt, sand, rocks and who knows what else....BUT I DO NOT REMEMBER OF EVER HAVING A SPROCKET TO SPLINE FAILURE...
So I have been thinking about using this since the solution changed from locking things down. Just been waiting to do my rear tire change at the same time.
Have had it around all my life as my dad was a navy and merchant marine, ship board maintenance electrician.
Regards,
Don
BTW: Don't get it on your hands or clothing. It doesn't wash out.
"Mariner's Choice NMCBT-8, Marine Grade Never Seez, provides extreme pressure lubrication and protects against seizure, galling, and corrosion both above and below the water line. Use on winches, cables, bilge pumps, anchor lines, porthole studs, rigging, hoist cables, suspension bridges, wind turbines, offshore rigging, or other applications exposed to harsh salt water and freshwater conditions. Requires about 41% less torque while providing the same clamping force on threads. Perfect for high moisture environments!"
Yes, well I know what fretting is but many of the pictures of the issue have the rust on the outside of the sprocket. So if the bolt is tight and it's sealed and fretting, how does the fretted material get out of the spline to the outside of the sprocket?This is entirely incorrect. The process is fretting. A form of corrosion not associated with moisture, but rather microscopic high pressure movement. The movement generates extremely small oxide particles the further promote wear.
