Many brands
Ordered a ISCI fronthandbrake for the RT, today. Not an easy process - ordering. ("out of stock" - "Will call you back" etc. ) but its ordered and upon installation - will let ya all know 'howit went'.
Sorry - I dont understand the -- "cruise disconnect feature" you mentioned ?
Tap the brake, disengage cruise control.
......but you can just tap the foot brake to disengage cruise control, Ron. You don’t need a hand operated brake to do that.
I would love to have a handbrake just for the cruise disconnect feature
Darn! You had me all stoked for a second! I thought it was an independent front brake system that ditched the Spyder's integrated braking system. Hope you like it!
ISCI is a "top-notch" Company; that builds even better products! :clap:
Good luck with the installation! :thumbup:
Please keep us updated after the install. I'm curious if the pull is like that of a standard front brake handle. I was at the Spyder In The Hills rally in TX and someone said it has a hard pull.
Definetly a harder pull. Completely different feeling than a normal hand
brake on a bike. When I first got it I didn’t feel like it stopped me fast enough but now that I am used to it I use it almost exclusively
***** I will say there is no way you can apply the pressure to the brake with your hand that you can with your foot and in an emergency I have been know to grab the hand brake and slam the foot brake at the same time. Hand part was probably useless in that situation and just done out of reflex. *****
My feelings and experience exactly !
What I don’t understand is why why it costs so much? Considering that it is basically a bracket with an independent self contained brake assembly and doesn’t interact in anyway with the actual system other than pressing the brake lever.
