Roadster Renovations
.PMK,
I am glad someone else agrees with me, here is a PM I sent doc a couple of days ago;
"The sleeve you are using slips through the inside of the bearing. The sleeve I am talking about would be larger in diameter then the sleeve you are using and would contact the entire inner race of both inside bearings only. The only way to install this type of sleeve would be to remove one bearing install the sleeve, and reinstall the bearing.
Most 2 wheel motorcycles use this sleeve system for the front wheel. The reason for this is no matter how tight you tighten the nut and bolt, the bearings will not get pinched together because the inner sleeve is between the 2 bearings on the inside. Our spyders even use this system for the rear wheel.
This would eliminate the need for the preload and folks could crank down on that nut and bolt all they want and no damage would occur to the bearings. Your system is placing a pinching load on the bearings, no matter how carefully you tighten the nut and bolt. This is because there is nothing between the 2 bearings on the inside race to prevent the 2 bearings from being squeezed together. The bearings are only being supported by the outside races in the roller.
There is also the danger since you are using the nut and bolt for preload as well as holding the roller, that a loose nut and bolt could spin in the arm if a bearing got tight or failed.
Now I know what you are thinking, all older cars with cone front wheel bearings were just like your system, adjust the castle nut for preload, then install the cotter pin back in. The issue is that a cone bearing is designed to endure this preload as the bearings are made like needle roller bearings.
The bearings you are using have little tiny ball bearings inside the inner and outer race. If there is any preload on them between the inner and outer race, they will fail, especially with the high speed that roller is turning.
All you would have to do is make a sleeve, pull one bearing install the sleeve, and reinstall the bearing. No changes would have to be made to your roller. When you tighten the nut and bolt, it will pull the 2 bearings together, but they will now be supported by the sleeve that contacts the inner race of both bearings only.
If you do not understand the way I am explaining this I could get a diagram for you. Just trying to save you some future grief, as the way this roller is designed in it's current form it will eventually fail."
I have doc's idler and spare roller in my hand, just received today. I am certain as the bearing breaks in, the pinching tension between the 2 bearings is going to change (because there is no spacer between the 2 bearings inside the roller). When that occurs, the bolt is going to loosen up on the idler and the bearings are going to spin on the spacers.
Doc, please do not take this as a personal attack. I have used many of your products and are very happy with them. Please, look at similar devices that use bearings like your roller does. They all have spacers between the bearings for a very important reason.
You have a good product here, just installing a spacer between the bearings could make it a bullet proof fantastic product! I would be more then willing to purchase a spacer from you to put inside the roller, if you offer one. The way it is currently designed I am not willing to install it on my Spyder.
And as I explained, if this does become an issue, we will address it. Why in the hell are you acting like this? I have said we will warranty the pulley 2 years and have stated that we will change it if need be. It is almost like you have made this a personal crusade to run our product down. You have stated your opinion and it has been noted. Move on.
