I think being relatively new here may have prejudiced your statement. Doc knows of what he speaks, and all he has spoken here, is the truth.
:doorag:
And you know this how?
:doorag:
Doc , I can't believe you didn't mention the windshield .....ARM... which been a problem since 2010 !!!!!! and the warranty fix on that is $ 700.00 ................:roflblack::roflblack::roflblack: ..... Mike :thumbup:
Are you asking what I know about Doc?
Yes. What and how do you know him. Then the bigger question is who are you. I'm not intending to be insulting. I used to be an investigator and asking questions and questioning people are second nature to me. My thoughts.
Re Idler failures
I have purchased the adapter kit for 15RT from Doc and also bought the BRP idler. I have not installed yet but am now hearing about failures or at least longevity issues. My question is should I proceed with the install of the BRP arm or bag the idea all together???
Hi Doc,
Could the premature failure of these units be due to them not being properly aligned with the belt? :dontknow:
Guys, on the modern motocross bikes we run rollers to control the chains. The older vintage bikes we ran spring loaded chain tensioners.
Those rollers were exposed to conditions far worse than the Spyder will ever see with one exception, duration of each ride and sustained rpm.
The off road woods racers or desert racers will see the sustained roller speeds and long time non stop use.
The key to those rollers surviving is having a sealed set of bearings and zero preload on the bearings. Metal shielded bearings will fail as they are exposed to water and fine grit that washes into them and also depletes the grease.
Additionally, and this will rub a lot of feathers the wrong way, but my experience in dealing with roller setups and similar setups on other double bearing designed products has always found that for the system to offer the greatest performance and survive, the inner bearing race must be rigidly fastened. In other words, the nut is tightened or torqued fully to spec. Any bearing preload is accounted for by the roller design, spring washers, or other methods. A system that does not clamp the bearings inner race is subject to seeing the inner race spin on the bolt / axle, or the bolt / axle spinning in the mount. These too can cause premature failures.
I have seen the video where the BRP roller wobble and play is demonstrated, in most cases that should not be a concern if the inner bearing race is tightened and the belt force runs down the rollers centerline. Granted it is a single bearing dealing with the full load.
The method utilized in the other brand to secure the roller does not offer a secured inner race. By design the nut is tightened to remove excess play but still induces a certain preload into the bearing that it may not be designed for. Also, as the roller is heated, the metal will expand, adding length to the parts and in theory increasing or decreasing preload which will result in premature bearing failure.
I also noted the other brand utilized a shielded bearing design. Shielded bearings are typically installed into a cleaner environment where the exposure to outside contaminants is nil.
I truly hope everyone running a tensioner has great results with them.
Myself, when I heard Lamont had backed out of designing or working on the Lamonster version of the tensioner for the RT I took notice. He never explained why, but no doubt is a person with an ear to the track regarding Spyders.
I have to respectfully disagree as to the inner races not being properly tensioned. That is what the inner sleeve does. It is crushed to the proper tension so that both inner races are held with minimal sideload. And as far as heat, after 80 miles an hour for 20 minutes, the entire roller was just barely warmer than the ambient. Time will certainly tell on whether our rollers will be an issue. if they are, we will redesign them. Time and miles will tell........
Doc, as you respectfully disagree, I respectfully disagree with your comments and reference your own video on installing the rollers to support my statements about bearing preload, and the inability to properly fully secure the roller fastener.
The stack up of parts associated to build up the assembly does not allow the bolt and nut to be torqued tight as it should, but rather only to a point where the bearings are not crushed. Additionally, without reaching torque on the nut to secure the assembly, there is inherent ability for the bearing races and the spacers to spin upon the bolt. These are not welcome in a high speed rotating device.
In regards to heat, yes your roller may run cool, but as can happen on setups designed with bearing preloads, often even a small amount of heat can alter the true preload. The heat may not be generated from the rotating roller entirely, but could be heat absorbed by the components from engine, exhaust, or road surface.
My experience on similar setups in harsher situations always requires the bolt to be torqued and any preload is absorbed by other methods or no preload is applied. On other devices rotating on a pair of ball bearings, the longest life span for the bearings and components, plus the highest performance (peak rpm over 40,000) required exacting alignment but most importantly a controlled preload that could be absorbed as heat entered the parameters or a design that required zero preload and was not affected by thermal changes.
