IWN2RYD
Like many of you, I unplugged the Fuel and Water temp outer gauges on our dash (Thank you all for this tip
hyea
Well after a lot of digging, and a few helpful PM's I finally found the gauges I am looking for. Originally I was looking for marine gauges for the "Water" concerns, but I never found the color combination of the face, bezel and lighting that I wanted.
One item I knew for sure they had to have was a white LED back-lighting.
At one point I even thought about putting Tweeters in the original spacing and replacing the front speaker with high end mids. But meh, we use our helmets now with the blue-tooth. so I figure that would be a waste in the end.
Anyway... I made a few phone calls, spoke to a few very helpful folks and decided on the Professional Stepper Motor Analogue Gauges, these two... Stack Oil Pressure 0-100 PSI (1/8NPT) Gauge and the Stack Battery Voltage 8-18 V Gauge
They are made for high vibration situations and water. The main thing I was looking for as I was doing my research was the Stepper version of the gauge world. This means the accuracy is about 2% and stability is superior.
I will get them in about two weeks (They are out of the Volt meter). I will install them shortly there after.
hyea:
