KID Ryker
Thanks. Got mine orderd
Did you install the Elka shock yourself and if so how hard was it to install?
Got mine yesterday and installed it today, took about 45 minutes. If you have the right tools the only thing you need to remove is the seat. The top mount bolt can be removed using a 15MM socket on a universal joint thru the slot under the seat, a wrench for the nut thru the bottom access, was able to torque the bolts as well.
The ride is much better and smoother and handling is much better in the curves. The best $167.00 I spent so far.
Sorry I should of taken pictures of wrench placement, but I didn't think of it until I was done.:doorag::yes:
What photo?Does the spring cap stopper (2 round plates on top of orignal shocck) from the original OEM shock need to be transfered/installed to the New Elka shock in this photo??????thanks,
Darrell
Dealer ordered shock for me .and gave me a $100.00 gift card to help pay for it:yes:
Reading thru this forum I've had mixed feelings. After my ride yesterday, something has to be done. After bottoming out over 6 times on a road that my lowered VTX had no issues on, I have contacted the dealer about the spring. No news yet on can am helping with the purchase, was not aware of the weight limit or the fact that the 15 F3-S wasn't meant for a lot of two up riding. By no means are we even close to the weight limit but evening the interstate I have to watch how I drive to avoid tearing anything up. Is it possible to put a car shock on? Something that will get me a little more mileage out of it? I'm averaging a little over 1k a month and that has been in the winter, so it will go way up now that spring is here?
Thought i would post this so more people could see..
New two up F3 shock
$213.49 plus $60 installation
see any difference..![]()
Not sure how this comes into play but based on these numbers it does not indicate much difference. It only compresses 1/4" less the than original shock.
What photo?
Take the orignal shock off bike and toss it in the garbage.
The Elka should be ready to go!! Who did you buy the Elka from??
You really should get Help from someone. Do you know how to adjust preload rebound. The adjustment screw needs to face front of Bike.
