Engine light
dvmdf
My 2008 RS SE5 (16,000 miles)threw a "check transmission" message and check engine light came on. All went away after the bike warmed up ( 3 miles of riding). Runs and shifts well. Went for a 10 mile ride, took 2 hr break, started again and the whole thing repeated itself with normal acting/shifting with the message and the light, went away after a few miles. Oil was a little low on the stick so I brought it back to full, tried to pull the codes "no active codes". Could it just have been a low oil? I've ridden before with the oil at the low end with no messages. Thank for your inputs.
Yeah..!!
Oil light is for oil pressure but low oil will cause check engine light. Oil condition can cause this as well. Keep an eye on it and make sure you change oil and filters when recommened or before...:thumbup:
