I had a CANBUS failure - anyone else have experience with this?
billz
I had the check engine light pop on and then go off after a few miles. Took it in and it came back as a CANBUS failure.... or hiccup. They said if it did go, I would lose my dashboard. Anybody else have any experience with this? This is on a 2018 RT Ltd. with just over 30k miles.
It happens. Anything can go bad. But I'd make sure my battery and battery connections were good before I started throwing money at an ECU code.
Concur with Ron. You want this transient to be battery related. If your battery is 3+ years old, replace it. Be sure to charge it overnight before installation.
If it isn't the battery, the 2018s have a problematic LHS Module/handgrip, which is a CANBUS node. Replacement is somewhat expensive.
