BertRemington
I don't understand how you accomplished this short
I looked at the Big Bike 41-162 trailer harness and I'm really impressed on how you managed to damage your Spyder electronics.
The BB harness taps into the left and right rear light assemblies using 5-pin SuperSeal connectors. You can't screw those up.
The BB harness gets its power from the Spyder via a 15amp fuse. I'm not sure where the connections were made but the picture shows ring terminals so I assume you didn't have to tap into any existing wiring.
That leaves the five trailer side wires. If you shorted any of them the BB 15amp fuse should have failed not a Spyder fuse. Unless unless...
Check LHS F7 (10amp); RHS F1 (15amp); RHS J4 (30amp)
PS a small LED flashlight is really helpful working in that frunk space.
