Thank you. :thumbup:
Don't trust my reading skills?
I've been doing it for a few years now. :2thumbs:
On the tire placard in your pic above, it confirms for all of us that your tires are meant to be LT tires (LT = Light Truck, which is a slightly different type of tire to a P tire, where P = Passenger, but I believe I can still work with the info given.
) The tire placard in your pic, the one on your vehicle, confirms for all of us that the GVWR for the vehicle is 9200lbs, with a Maximum Front axle GAWR FRT of 4200 lbs and a Maximum Rear axle GAWR RR of 6084 lbs; and it also shows
TWO tire pressures, one for the front, 60psi; and one for the rear, 80 psi - but AFAIC see, there is only one size & rating of tire shown, an LT245/75R16E - correct? Still with me so far??
Still don't believe me? :lecturef_smilie:
And in the pic above, it confirms that those LT245/75R16E tires are rated to carry a Maximum of 3042 lbs at 80lbs, right??
I must admit that I am somewhat surprised to see that the tire placard is telling you to run the
Maximum Rated Pressure for the tire on the rear
regardless of the load back there (altho maybe the Owner's Manual that the placard directs you to might have some more info in it?? :dontknow: ) that is not at all common in my experience; but I strongly suspect that neither you nor anyone else is
ALWAYS carrying the
Maximum Rated Load for that tire in the back of one of those trucks. Still, considering that you've got
TWO tires on the rear axle (or is it a dually?) that means the tires
COULD conceivably carry as much as 6084 lbs back there, which does match the GAWR RR. But then surely, because you're only meant to be running the one size and rated tires, you could conceivably also carry as much as 6084 lbs up front too?? Only the front axle rating GAWR FRT is roughly a little over 1/4
LESS than the rear axle rating GAWR RR
AND similarly less than the Maximum Rated load carrying ability of a pair of those tires;
AND ALSO, the tire placard's recommended pressure for the front tires is roughly about 1/4 less than that of the rear tires, isn't it?! :shocked:
So those front tires, which according to the tire placard only warrant 60 psi in them, obviously aren't ever expected to carry their Maximum Rated Load, are they?! After all, the Front axle rating for the vehicle is only 4200 lbs, rather than 6084 lbs - and so the tire placard recognises that the front tires are only ever going to be carrying a lighter load than their Maximum Rated Load, and so it says that you only need to put 60 psi in the front tires instead of their Maximum Rated Pressure of 80 psi! Clearly, not even the '
this one size/pressure suits all users, conditions, & loads' tire placard assumes that you still need 80 psi in the front tires cos they won't ever be fully loaded, even if it does assume that you
WILL always be carrying the Vehicle and the tire's Maximum Rated Load when it comes to the rear tires... :banghead:
So like I said earlier:
If you're not carrying the Maximum Load the tire is rated for on each tire, then you shouldn't be running the Maximum Pressure that tire is rated for.
However, I do wonder what 'other info' about all this is in the Owner's Manual?? :dontknow:
