RICZ
You can draw all the fluid out of the reservoir, but don't touch the brake pedal until you refilled it.If I remove all the old fluid from the reservoir, won’t that let air into the system, which would mean I’d need buds to flush the abs? I was hoping to just flush and not let air into the lines.
Also, when installing the speedbleeders, is much air allowed in?
Than you for your expertise everyone!....brian
When removing the bleeder, air won't go in, but fluid will ooze out, so have the Speed Bleeder ready to install and have a rag wrapped around the base so no fluid gets where it shouldn't.
FYI: Use DOT4 only. Never use DOT5 synthetic - that's for racing - unless the manual calls for it.
