Here is the information I received from Speed Bleeder Products. They have been very responsive and informative as to application. They also offer a stainless steel version, which is quite interesting.
Let me know if it is too small for you to read and I will send you the file.
I have been asked how a Speed Bleeder works and why it is a good idea to replace the OEM bleeders with this upgrade.
A Speed Bleeder uses a Spring Loaded Ball Valve assembly. It does what you do when you open a bleeder with pressure on the fluid, bleed and close. The differences are. A Speed Bleeder opens and closes automatically and reliably. 1 person can do this with a speed bleeder whereas it usually takes 2 people to do it with a standard bleeding process. When you do this manually, you can easily get air in the system. Not good! With a Speed Bleeder, air cannot get into the system. And, bleeding is much easier with Speed Bleeders in place.
Picture A below shows air in the system with the ball valve closed. Picture B shows what happens with the Speed Bleeder is in the 'Open' position and the hydraulic pressure overcomes the ball valve which then allows the fluid and trapped air to escape. Picture C represents the ball valve closing and sealing the system as the hydraulic pressure decreases. Fluid/Air can only go out, they cannot get in as this is a 1-way system. Simple and effective.
This does not take into consideration the other bleeding alternatives like a pressurized bottle apparatus. But of all the methods I've tried. This is the easiest, quickest, and least messy way I've found.
A problem I had with all other bleeding methods is air sneaking past the bleeder valve threads. And yes, I have tried them all. Speed Bleeder solves this by adding a meguselum to the threads of theirs that acts as a seal.
Previous posts have mentioned the task.
The calipers should not require being removed. The front wheels will need to be removed. So in that regard, you will need a proper torque wrench for reinstalling the wheels.
Focused on bleeding the brakes, there are 4 bleeders that require access. I assume you are accomplishing a flush and bleed. With that, to save time, start by removing all existing fluid from the two reservoir segments.
Refill the reservoir with correct new fluid. Typically, the sequence is left front, right front, rear, then ABS module. Each is bled until new fluid is seen in the catch cup for old fluid. I have found it best to accomplish the flush where the first pass removes essentially all old fluid. The second pass ensures clean fluid on account of the catch cup has been emptied.
As you have read, some folks install aftermarket Speedbleeders. Others, myself included have not yet bothered to do so.
