Baron14y
Isn't your Spyder a Ltd, that comes with a compressor, height levelling switch, and the 'Automatic' ACS?? If so, then it's probably the automatic bit doing its thing! The Spyder's ACS has a pre-set height static ride height & it'll automatically adjust the pressure to return the ride height to that pre-set, pretty much regardless of what ride height/pressure you might want in the air bag! :lecturef_smilie:
So you might pump it up to your preference, but as soon as you start riding, the ACS will start returning it to its pre-set ride height by increasing or dropping the air bag pressure!! :gaah: If you have access to BUDS, or have a dealer who does & who knows how to use it, you can change the pre-set to something more to your liking!hyea:
If you don't have the 'Automatic' ACS, but instead have the basic 'Schraeder Valve Only' version, then it could be that you have some dirty 'press to fit' air line connectors that need cleaning; or possibly more likely, some pin-prick holes in the lower sides of the air bag caused by fine gravel being caught between the air bag & the seat below it & then grinding away holes over time, so that when you pump the air bag up, the holes open & start bleeding air out; only once the air pressure gets low enough & the bag collapses down onto its base/seat again, the tiny holes are sealed off by the weight of the Spyder pressing the sides of the air bag onto the flat metal seat below the bag. :dontknow: You MIGHT be able to fix this by adding a small squirt of Slime thru the Schraeder Valve, but only if you're SURE you have the manual single line system without the valves & compressor that could otherwise be clogged & rendered inoperable by forcing Slime into them! :yikes: Otherwise, it's either live with it or it's time for a new air bag &/or air lines, connectors, etc.![]()
Good Luck! :cheers:
Thank you Peter.
