According to my reading, that code,
P0127, is because the
Air INTAKE Temperature is too high, not the exhaust manifold?!? :dontknow: And if that's the case, then it's just cos it's bloody hot out!! :yikes:
I've seen it here in Oz quite a few times, and it's generally not a biggie - effectively, it's just cos the Spyder has been either parked in the blazing sun for too long; or it's been ridden in the heat, then shut down for a short while, usually while it's been left sitting in the sun, and heat soak has significantly increased the under-tupperware temps such that the air intake temp is too high. Sooo, starting it (if you can!
) and then running it at low/medium revs while ryding gently for a minute or so will usually fix it; but if necessary, rolling it into the shade &/or putting a sun-shade type cover over it, maybe even just blowing some cooling air into the vents/air intake ducts will sort it PDQ!
hyea:
Personally, my 2013 RT (the model with the real under-tupperware heat issues! :shocked: ) has never left me stranded - if I hafta shut it down while it's in the blazing sun & leave it for anything between about 1 minute to 30 minutes, then I get that warning. But, at least for me, so far it has JUST been because the air INTAKE temp is bloody hot, so starting it &/or getting some cooling air/air flow under there has sorted it pretty much straight away. Those I know of who've been either too scared or unable to do that 'start &/or air/air flow' thing have had to wait up to a couple of hours for the under-tupperware temps to drop, but none have had any lasting issues - well, none that we've found yet! :lecturef_smilie:
So try not to park your Spyder in the blazing sun on hot days, especially not when it's already warmed up from a reasonable ryde, and you probably won't see that code ever again. If it's hot enough that you do, then maybe you need to think about carrying some cool/cold water that you can pour over the tupperware &/or around the region of the air intakes, just to help bring the temp of the intake air down a little! :thumbup: And it might be worth asking yourself if
you should be ryding in those sorts of temps too?!? :dontknow:
Good Luck! :cheers:
