jcthorne
Well-known member
This is a new model that is currently being tested.
After watching arms stick, idlers fail and springs break, we decided there is a need for another choice.
This model uses the time tested, maintenance free, dual compression spring tensioner.
The tension is fully adjustable so you can use just the amount needed to get the job done, usually somewhere between 5-10 Lbs. depending on the severity of the vibration.
The mounting bracket is 3/16' stainless steel and is secured to the swing arm with a 3/8" U-bolt.
The tensioner also required a 3/16" stainless arm added to clear the various components.
The idler is our standard long life high speed idler that uses 6203 C-4 bearings, and has been machined as small as possible to provide maximum clearance.
The instructions are available to look over now if you email meView attachment 163903View attachment 163902View attachment 163905View attachment 163904, the tensioner will be available once all testing is completed.
[email protected]
So glad to see you back in this product line. Have used and appreciated the quality of your products for years now.
