Flamewinger
~~~Just guessing but I would imagine (from what you’ve said), when you have your smartphone connected to BRP GO or whatever the proprietary onboard electronic wizardry is called, perhaps the clock function on the dash is being run through your smartphone, then it's coordinated with the atomic clocks
Best,
Jake
Reddick Fla.
Even a blind squirrel finds a nut every once in a while
No, as a matter of fact the dash clock is not from the phone. The dash firmware uses the Bluetooth connection to make/receive phone calls and uses the BRP Go app to allow certain apps to show and work in the dash. The phone doesn’t provide any other info.
