I looked into my tail light (no running light, just brake light) and sure enough, it is a dual filament bulb, small one for running light and ticker (brighter) one for the brake light. The running light filament had blown which was clear looking up close.
With stock spares on hand (1157 standard) I just replaced the bulb.
Ok…. some say it can not be done (replace the tail lights with the BRP Rear Sports Rack installed), but as we know Neez posted a mod where you trim the plastic from the lens boxes and the bulb/socket combo can slip right out !!!! ABSOLUTELY.
Neez - thanks for your previous post on this !!
Below are some photos of the procedure I used, which shows close up shots of the stock lens box (before and after trimming the unused and unrequited plastic area) to make getting to the bulb/socket assembly MUCH EASIER then taking off the rear sports rack… HECK YOU DON'T EVEN HAVE TO TAKE THE LENS BOX OUT AT ALL, EVEN FOR THIS MOD. I followed Neez' idea (Thanks Neez), except I modded the lens boxes without even removing them from my Spyder. I DID NOT move, loosen or even touch the rear sports rack.
I followed the owners manual under road-side repairs, page: 113, 114 (RS 2010) as follows:
1. Remove the panel under the passenger seat by unscrewing the 7 Torx screws (remove the rear wheel splashpan)
2. Partially remove the right (or left - which every you need to replace) side panel by just removing the 2 plastic rivets under the seat.
3. Disconnect turn signal housing connectors.
4. STOP - This part says to remove the screws to the lens box, drop the lens box and you have complete access to the bulb/socket assembly. HOWEVER, as we know, with the BRP Sports Rack installed ONE of the two screws in the lens box is inaccessible - covered by the part of the BRP sports rack.
<HERE STARTS THE MOD>
5. Looking at the bulb/socket assembly you see at the lower corner of the lens box is a section of plastic that is unused. I trimmed (similar to Neez's mod) about 1/4inch-1/2 inch off each of the lens boxes without removing them. Now this tiny bit of extra room allows you to get your hand in behind the lens box and direct access to the bulb/socket assembly. (picture help explain below). This tiny extra section of plastic will not be missed and does not harm anything.
6. I used cutting pliers to start a cut into the plastic, and a Dremel to smooth out the area.
THAT'S IT.
Here are some photos that I hope clearly indicate the area removed and how much easier this makes accessing the bulb for quick and easy road-side maintenance, even with the rear sports rack installed:
The issue - right running light filament burnt out (first time so far - 18,000km):
In conclusion, with this mod (just trimming about 1/4-1/2inch of access plastic from the back of the lens boxes) changing the tail lights can totally be a road-side job. No need to loosen, move or even touch the BRP Rear Sports Rack, if you have it installed.
Now, the bulb can be accessed from just removing the 7 Torx screws if you have small hands - however, for a little extra room I like taking the side panel out a little (very easy - just lift the two rivets just above the signal lights on the upper panel) and it is easy access. Both bulbs could be changed at the road side (for example, if you get into LIMP mode when both lights blow) in about 10-15mins maximum.
Hope that helps.
Cheers,
Dean
