Brake code
KGal
I have a 2010 RT SE5. It is showing the icon of "!" on the screen indicating brake failure, then showed a code of "P0000". Everything seems to be working fine. Fluid levels are good. Anybody have any ideas?
Little checking..!!
as said the fluid level is very exact may seem fine but needs topping off. If you inadvertantly rested your foot on the brake for a spell you can get a brake code that clears. Check pads just in case...:thumbup:p
These bikes are pretty touchy about oil and brake fluid levels... :shocked:
Let them get about six drops low... :yikes:
Roger,
Thanks for the "P0000" explanation! :clap: This is the first time that I've heard it described this way, and it certainly makes the most sense. :thumbup:
