Wildrice
Does that mean the VCM has a bleeder port? I would think the little fluid that is left would dilute into the fresh new fluid.
In my opinion the VCM brake fluid would dilute into the new fluid. The manual states to start brake bleeding with the front brakes but I'm still in favor of starting with the caliper farthest from the master cylinder. The manual also states there is a bleeder valve on the VCM but unless you have the BUDS equipment I won't worry about bleeding the VCM as long as each caliper's fluid changes from dirty to clear brake fluid. The manual is lacking in directions & info--some parts state using Dot 3 & Some Dot 4. My master brake cylinder cover states use Dot 4. Dot 3 will boil from heavy braking. That has happened to me in my old 24' motorhome coming down a mountain--it's a very unpleasant feeling when the brake pedal goes to the floor & no braking occurs.
Darrell
