I fought the exact same problem as you're having. Go here to see what I finally ended up doing to get the tracking to stay, and why the belt wants to move when you tighten the nuts. http://www.spyderlovers.com/forums/...nt-Problem-amp-Question&highlight=flange+beltThanks. I will try this! I could get the tension spot in but as soon as I tightened that axel it was all she wrote!
Just to make sure I understand this. If I need to loosen the tension it's turning the left hand bolt anti clockwise and then I should also have to turn the right belt bolt anti clockwise? Also, should I get my tension correct first before messing with the belt bolt?
Correct. Go in small turns, 1/8-1/4 turn at a time. Those adjusters being that loose probably didn't help your tension changing when you tightened the axle. Any time you have to loosen an adjuster I'd tap the axle forward.
Ugh what am I doing wrong here? My belt always ends up like this.and it seems the belt alignment piece is loose![]()
These are the numbers I've gone by that BajaRon had posted.
THANKS for all the good discussion.
I am changing out my rear tire tomorrow on my 2013 ST. All the discussion has been for earlier models.
So...my in air belt tension should be between 202 and 236 it sounds like.
HAS anything changed with BRP or users since all this good info has been posted?
THANKS!
ANDY
Based on the technical service bulletin the range is about 140 to 236, whatever works to keep the vibration at a level and speed range that makes you happy.From what I've seen recently the numbers have been drastically reduced to something like 140-180.
Yes. Off the ground with the swing arm hanging at max shock extension is the only way to know for certain you are in a consistently repeatable physical configuration, particularly bike to bike which is what the service manual has to address. The tension changes with swing arm movement so measuring it with the wheel on the ground can give varying readings depending on air pressure in the shock. I suppose if you released all the air out of the shock every time you measured the tension with the wheel on the ground you could get somewhat repeatable readings. Determine the method and tension that works for you and stick with it.Is that measured with the rear wheel off the ground?
Thanks
Andy
