the sprocket edge has a slight angle to keep belt from riding UP. So the gap on top will be a smidge wider than down at the teeth. That is where the credit card gap should be checked. IF the belt is riding too hard on side flange, it will squeal!!!
But if it's NOT Squealing, don't sweat the small stuff!! :thumbup:
And if it's still concerning you - despite being told by more than one person here that the belt WILL & DOES walk around on the sprocket during use and that if it's not actually riding up on the sprocket's raised lip, then even if it doesn't 'look' ideal, it's still OK - maybe you should learn how to do it yourself?? You wouldn't be the first nor will you be the last to make the effort to learn how to do things like this yourself simply because you don't trust the dealer/dealer's techs to do it properly! :banghead:
Or if you've still got warranty, then why not just... wait for it.....
Ride More, Worry Less!? :dontknow:
Either of those can be a viable option, and anything else is really just likely to stress you out needlessly even more than this has already, which effectively negates the point of owning a bike/Spyder, doesn't it??
Just Sayin'!!
