Anywhere in Jacksonville FL that fits non-stock F3-T Rear Tires?
Jmack
Hello does anyone know of shop in Jacksonville Florida that will install a non-stock rear tire on my F3? The Can am dealerships here won't do it unless its the the one recommended by BRP. I currently have a General AltiMAX RT43 Radial Tire - 215/60R15 94T that was on it when I purchased my Spyder. I love it and the tread life has been great!
Thanks,
Jeff
If your able to remove the rear tire yourself then you can take it to any tire shop and they should be able to change it for you.
Thank you for your response! I was trying to work up the courage to do it myself. Taking it off and putting it on would not be a problem for me. BUT I do feel intimidated that I would not put the wheel back on straight. I don't understand what mechanism keeps it aligned.Thanks again.
Jeff
Seminole Powersports in Deland will do it. Not too far from you. Great shop. Very knowledgeable. Expensive, $150/hr. labor. :thumbup: Tom :spyder:
Purchased tire from Discount, took about an hour to remove, an hour to replace wheel on Spyder. Used RideOn tire balancer/sealant, pleased with results... Hubby Bear has every tool known to man (& woman) try to do all my own maintenance...
