rjinaz86323
With the 225 60 my Spyder speedometer matches my GPS speed.
I didnt know the speedometer is not correct on the Spyders, So you are saying my 22 RTL is not accurate ? and if so, how far off ?
About 3 mph.
About 3 mph.
On the other hand, Peter, the 3 mph number has pretty much been the only number I recall seeing quoted here on the forum. I was going to say 3 mph but K80 beat me to it! But your comment is true. One person's error is no guarantee the next person's error will be the same.That was only on your Spyder K80, and the variation may not be the same on anyone else's Spyder or vehicle! :shocked: The variation can be & quite likely IS different for each different machine, altho because the gauges are all made basically the same way, some errors may be juust something vaguely similar; others may be very close to yours; but just as equally, there's very likely some out there that are waaayyy off that 3mph error you were lucky enough to get!! So please, be aware that while your error might be close to someone else's, THE ERROR CAN BE DIFFERENT FOR EACH MACHINE &/OR GAUGE! :lecturef_smilie:
I have read this thread with great interest and appreciate everyone’s comments. Tire pressures have been commented on. Everything I’ve read says to run the pressures on the frame tag which would be for the stock tires. My question is, with the stiffer sidewall construction of car tires, what would be a good starting point for pressures?
I thought I read some where that the 225 60 15 would put the tire very close to the front of the swing arm on a 2020 RTL is this right?? That's why the 215 60 15 was the one to use because of the outside diameter of the tire and also it raised the back of the spyder up higher because the air adjustment went off swing arm not true height of rear of bike say back fender from ground. Lots of good info THANKS. TO EVERYONE
General 'Rules of Thumb'
Typically, you will trade improved traction (especially wet traction) for a higher mileage tire. A long lasting tire has to use a harder compound which will not grip the roadway as well.
I do not recommend 'Summer' tires in any format for the Spyder/Ryker. Unless you are only going to be riding when pavement is 70 degrees or above. Once the pavement begins to cool, (especially as these summer tires begin to wear) they tend to get slick. It is not so dramatic in a car because of the additional weight. With the relatively light Spyder (especially in the rear) the difference can be pretty dramatic.
If you ride when the pavement is 40 degrees or less, Summer Tires can be very slick, no matter how good or dry the pavement is. This tire compound is specifically designed to give extremely good traction with warm or hot pavement. They are a 1 trick pony. For most of us, we need a good 'All Season' tire.
At the very least. If you're running a 'Summer' tire. Be aware of these tendencies.
In regards to your post #37, ( above ) having input from someone knowledgeable about actual racing is very valuable. ...... The next time you are discussing this with them ask how many of these race cars have traction systems that are controlled ( and limited ) by Computers - like our Spyders are. I suspect they will say NONE. The Spyders are more limited by those systems than any structural limitations. The traction supplied by " all season " tires easily exceeds the limit the computers are designed with...... Mike :thumbup:
