I did mine last week, connect the tank vent to the other overflow line from the canister with a plastic or preferably metal connector or inline fuel filter. They are 2 different size hoses, but I think a 1/4" fitting should fit both, with the tank side being a tighter fit. Be sure to plug the hose going to the purge valve and leave the purge valve electrical plug connected. My dealer said "good for you".
So what is the real benefit here?
The cannister is a source of many discussions lately. Search in the GS/RS shop talk forum as they were quite active in removing the cannister.
Some of the reasons to remove it:
-It can't melt if it isn't there
-Reduction in 'gas smell' after shutting the bike off
-Gas dripping on the floor from the cannister overflow tube
-The 'good' effects of having one are eliminated once you overfill your gas tank and the cannister is flooded
-More space under the panels. Its crowded under there and freeing up space can only help heat flow.
Others may suggest more benefits
....Why do some think it would cause a warranty issue? How would a missing canister cause another part to fail? If anything it simplifies the system for less failures.
The downsides... :shocked:
If a BRP tech ever catches you; he'll smack you on the nose with a rolled-up newspaper! :lecturef_smilie:
Because manufacturers will use any excuse they can not to cover a part.
Guess it depends on the work.
I've been into modded bikes, jetskis, jeeps and now the Spyder. Never have been denied a warranty repair for something that broke unrelated to a mod that's been in place.
The key is to build a good relationship with the dealer. They make the call and have the ability to make a big deal about something or not. Mine doesn't care about most of the mods we do because we aren't trying to get something covered that shouldn't be.
WAY to many people on here are to quick to go directly to BRP first. By doing that you burn the bridge with your dealer.
If your that worried about your dealer making stink about the missing canister you could always put it back on if you have to take it in for work. It takes only a few minutes.
Do NOT call them and ask this! :lecturef_smilie:
You already know what the answers are; don't pin a target on your collar!
And the dealer doesn't have the final say with warranty issues. The parts in question are sent back to bRP; they probably look them over carefully! :shocked:
I was thinking asking them face to face how they felt about minor mods like the canister removal, exhaust changes. This way I could get a feel of how they feel. :dontknow:
The good side is some of these service guys where I bought at, also ride Spyders.
I just got my yellow 2013 Rt back today from recall. It was there for 31 days. The double brake cylinder and the evaporator canister had melted along with various tube etc.
The tech said the bike should have caught fire. I was lucky.
I asked about removing the evaporator canister and was informed that it would void the warranty.
Until the warranty runs out I'll risk it.
