Anti freeze/ Prestone
Rookiespyder
After doing a oil change I noticed that my anti freeze is down below the cold level. When it is sitting for a few days should it be topped up to the cold line or between the cold and hot line. Thanks
Cold line, and be sure to use the correct type of anti freeze.
From the manual:
For best performance, use LONG LIFE
ANTIFREEZE (P/N 219 702 685) or
equivalent.
Neil
Yup! :thumbup:
If you overfill it: you're just putting antifreeze on the ground... :banghead:
And you don't want it, where a family pet can get to it. :shocked:
Make a mental note as to where the coolant level is when cold. Ride it several times and then check it again when cold and unridden. If it's going down you may have a small coolant leak. It's common on this model for the hoses to move because of the oetiker clamps used by BRP. There are several threads around about that topic.
FYI :thumbup:
Anti-freeze
YES, all good TIPS. :coffee: I had a antifreeze leak and it was from the water pump. Dealer first thought it was a clamp. I had to remove the right engine side panel to find the leak. :thumbup:
