What diameter tire would I need on my 2010 to hit 40 mpg? Getting 27mpg now....
Anything on the rear from a 205/50R15 thru to a 225/65R15 should be able to do better than 27 mpg (you might not on a 195/50R15, but they rarely fit safely on the rim anyway!
) But to do closer to 40 mpg consistently on a 2010 with an early Spyder's V-Twin motor, you'd probably need to replace the plugs and leads, swap the air filter for a Hi-flo unit, change the oil to fresh lightweight oil, change the oil filters, do an evap canister delete/bypass, toss the catalytic converter/primary muffler, fit a free-er flowing exhaust/secondary muffler than the stock choker is, and then get a quality ECU Upgrade to a better state of tune - even then, it'll likely take consistently riding pretty conservatively.
You
might get half way there on just the stock tune and
reeeeeaaaalllly conservative ryding, but you're probably going to be chasing your tail to get anywhere near that 40 mpg with what's probably an aging motor by now, plus tired plugs & leads, etc, and an engine still in its factory spec de-tuned condition.
But if you bring everything up to par as mentioned and get that ECU Upgrade, then resist the temptation to explore the limits of its new found power & revs, but still manage to keep the revs up over about 4000 rpm
most of the time without topping 8/9000 too often, you should get close.
These V-Twin motors are relatively high performance, and high revving motors that
really don't like running around at low revs, they
especially don't like lugging around, which is not good for the clutch either (Yes, the SE's do have a pretty conventional wet clutch with the addition of rev based centrifugal engagement), and these motors have been
significantly de-tuned at the factory/manufacturing stage so that they are never going to be running at their best/most efficient in stock trim anyway!
That said, even with the Upgrade, they need to be running in their 'sweet spot' to run at their most efficient, and that means keeping the revs up over about 3500-4000 rpm. There's a lot of discussion here on the Forum about all this, with examples and others' techniques for achieving it, as well as examples of the damage that can occur if you consistently run them too low in their rev range!
Still, we really didn't buy these Spyders for their fuel economy, did we!!
