Adding additional 12volt adapter
Kredab
Can anyone tell me if the optional cig lighter adapter in the frunk has wires already there ? You just have to buy power outlet ? If yes, what color are the wires and what is the color of the hot wire ? Also would that be hot all the time .
I'm think about putting power adapter in the speaker grille, any details how you ran the wire would be nice, did you go to battery ? What size fuse did you use? Is there a switched power line that is easier to get to? Did you run wire on (sitting on spider) left side or right ?
Sorry so many questions , 2016 Spyder RT-S:spyder2::spyder2:
Yes in the frunk on the left side when you are on it.open the frunk and you will see a plug and behind it 2 wire and they are on theaccessory so depend where is your fuse on 6 or 7 position you will have or notpower with the switch off.
Black for ground -
odder color for +
