Absolutely Amazing after Installing BajaRon sway bar!
Change your front tires to car tires and you go up one more level in handling..each mod ups the handling of the spyder and you just did the #1 upgrade..tires/shocks just ups the fun factor..Ron's sway bar should be a factory option.
Thanks for the advice. So changing the front tires makes that much of a difference? I will have to research this for sure.
Tyres are also my next mod, still pondering bout the vredesteins quatrac, but I am a nice weather motorist, and between the michelin crossclimate..
But have to agree with AZCANAM, it does make the bike a whole other beast. now it's actually point and shoot at twisties.
It's just amazing how BajaRon's swaybar, changes ride dynamics.
Based on advice and comments offered here, I swapped the front tires for Vrederstein Quatracs on my 2015 RT-S and recently added Ron's anti-sway bar and am very, very happy.
Having followed advise of many on this site, I switched to Q5’s on the front and added a Baja Ron sway bar! Coming this month will be a laser alignment, my local dealer in Albuquerque finally bought the tools needed to provide this service! All these improvements make the ride so much more enjoyable!
I think that combination would work great! Two very good tire manufacturers and I agree with the Kumho for the rear. Think you will feel a much better ride once you have them installed.
What do you guys think about this combo? After reading through the threads, this seems to be the ticket. I wanted to maintain the "beef" in the rear end being that kind of guy so I chose the Kumho. Feedback would be appreciated.
Do be aware that, especially as they age beyond about their half life (for most that'll be something like 10-15,000 miles or so :rolleyes: ) the Kumho's tend to gradually wear into layers of compound that are a little harder than the brand new compound, so you might find you need to drop your tire pressure a little more (1 or 2 psi maybe?! :dontknow: ) in order to maintain the high degree of wet road traction they are capable of (if they aren't providing fantastic wet weather traction from the start, then check/lower your tire pressure a touch! ;) )
But regardless of whatever pressure you are running, I suspect you'll find the Kumho an improvement in all respects over the OE spec Kenda, and if you are running it at or near the 'right' pressure for your load/riding conditions (I'd expect that to be somewhere between 14 psi min & 18 psi or so max :D ) then that'll be a 'great improvement' or possibly even better! :thumbup:
Thanks Peter & Don.
For the moment I just ordered the front Vreds because I have not found a shop willing to mount the rear tire.
Discount tires will mount and balance the fronts though. They will arrive tomorrow and be on the Spyder by Wednesday.
I had the Kumho and was not impressed. It was fine when it was brand new, but as Peter said, it got pretty scary when the tread started wearing down. I tow a trailer on most of our vacation rides, and I stopped in OH for the night just a few hours from home, because the tire had gotton so bad in the rain. Dry traction was still good.
I have been a big proponent of mounting car tires to Spyders from early on. Frankly, the OEM Kendas are atrocious. But I have found the same thing you mention to be true with some of the car tires I've tried. The Toyo Proxes TR1 was my 1st, and the best car tire I've used. It wore evenly across the full tread area, ran smooth and gave me good traction, wet or dry, all the way to the end. But this tire doesn't come in sizes that we can use anymore. The Falken 912 that I am running now came highly recommend. And it does fine in the dry. But gets very greasy in the rain. In my opinion, probably just about any car tire will work well in good weather. But not necessarily in the rain, or as they wear. Still, worlds better than the OEM Kendas and a worthwhile compromise for just about everyone.
Enter the Kenda Kanine. Kenda builds the OEM Spyder tires for BRP based upon BRP specs. Not NECESSARILY a Kenda issue. There was a 12 year patent or Non-Compete (not sure which) on them which has now expired. Kenda CAN build a decent tire. Now I know why they didn't for the Spyder. From the feedback I'm getting, which is admittedly somewhat scarce, these new Kenda Kanines may be the answer I've been looking for.
I am always looking for a better product or way to do things. Though car tires are a big improvement over the OEM Kendas. They, for me at least, have not been ideal. I really want to stay with the OEM tire sizes, which have become harder and harder to find in a car tire.
With a car tire you're always going to be trading traction for longer life. A car tire is always going to have a lot more pounds per square inch on the tread area built into the equation. So, for other than race tires, rubber compounds are harder. Traction, for a car, is still good because of the weight/pressure on the tread surface. Not so with a Spyder application. Especially in the rain where the rear tire on the Spyder is prone to hydroplane because it is very light with a wide tire.
For many, car tires are a great trade-off. As it was for me with the Toyo. But for me, I'd be willing to sacrifice some longevity for improved traction. Especially in wet conditions.
So, I am swapping all 3 tires out for the new Kenda Kanines. The Falkens I am running now are almost new. But I don't like them, so it isn't a big sacrifice and I want to know if the feedback I'm getting on the Kenda Kanines is accurate. It appears that Kenda has addressed the things I hate about the OEM tires.
#1, the weak tread area with just 2 plies on the OEM Kendas. This causes the rear tire to balloon out at speed, reducing the contact patch to about 2.5 inches. This is why they wear out so quickly in the middle. The Kanines have a 3 ply tread construction (car tires typically have 4 ply. But again, this is a weight carrying component). Will 3 plies be enough to resolve the ballooning, reduced contact patch, uneven wear issue? From feedback I've gotten, the answer seems to be yes. We'll see.
#2, many of the OEM Kendas are not round, (which you can't fix). And even if they are round, it takes a lot of weight to balance the wheel. From feedback I've gotten, this has also been addressed in the Kanine. Again, we'll see. I will know the answer to this soon as I plan to have them mounted this week.
#3, then we could talk about the cord failures with the OEM tires. Design or production flaw? We'll see.
The rubber compound on the Kanines (as with the OEM tires) should be better suited to the weight and traction needs of the Spyder. I am hoping that the Kanines are a good option for people, like me, who are willing to trade some tire mileage for better traction. I have not promoted or listed the Kanines yet. I want to run them first. But I do have a source for them. I've already sent a few sets out. It's early. But so far, customers have been happy.
I am hoping it doesn't take 12 years to get a decent tire for the Ryker!
I will keep you posted.
Thanks for your input Bajaron. I am now going to "wait-n-see" if the Kanine is the right tire to put on the rear. In the mean time my Vredestein's will be installed in the fronts soon.
I am really hoping they work out. I may be hoping too hard. We'll see...
Well BajaRon,
As you know I could not be happier with the Vredestein's in size 165/60/15 I put on the front wheels.
Since the dealer is willing to mount an OEM similar tire for "free", I decided to take a chance and put the Kanine on the rear. Since the tire is $100 installed why not?
The Kanine will be installed on April 29th. I will provide feedback for sure. Stay tuned...
Well BajaRon,
Awesome! I am happy to get any feedback I can. I'm not saying car tires are a bad idea. The right car tire can work very well. The problem has been the dwindling supply in sizes that fit the Spyder. And zero alternatives for the Ryker. I am hoping that the Kanines prove to be a reliable alternative giving everyone another option.
I am encouraged by the, so far, positive reviews.
Has anyone noticed the improved (IMO) fender gap with the Vred 165/60/15? To me another benefit.
'Improved' in what way?? :dontknow:
Larger? Smaller? Tire less recessed into the wheel well? Or further out of the wheel well/filling the space available better?? :rolleyes: Enquiring minds want to know what it is that you see as being 'improved' by fitting those Vredesteins?? ;)
