RickWB
In terms of the spacers, it was easy for me (not bragging). You push the screw in partly, then put the spacer on by back it up enough to get spacer positioned, then continue pushing the screw all the way thru.
I can't remember if it is the 10mm or the 13mm, but you will need two of them because otherwise the nut on the other side will spin. If I remember correctly, it was the shields near your foot that needs two wrenches. Personally I used a rachet and a wrench of the same size.
The kit does come with "super glue" if you want to set the spacers in place first.
Installed the BajaRon swaybar and links yesterday. I removed old links and installed new links with cycle on the ground. I had purchased a 5/16" dowel on the weekend, but my wife was away with the car, and that is where I left the dowel. There was no super glue in my kit, and my wife's e6000 glue had hardened up. I used a nylon zip tie to thread the upper link assembly through and was able to get the bolt through as I slowly pulled out the zip tie. Two 13 mm wrenches used for fasteners, one was a ratchet wrench.
Time for a ride later today.
Rick
