Am I overly concerned about the RT??????
Yep! :lecturef_smilie:
Not particularly aiming this at you, BR, more just putting this out there for those who are particularly worried about doing basic stuff on their Spyder/Rykers... Remember, it's
JUST an engine & driveline in a motor vehicle, just like any other.... sure, there are some things you might not see on every other motor vehicle out there, but the only real differences between an RT & an F3 or an auto are that you've gotta take some Tupperware off before you do too much; there's a few fairly obvious 'safety items' you might not want to risk playing with; and because it's fuel injected instead of carburettored, there's a
few things involved with that you probably can't/shouldn't try to do yourself!
But checking &/or changing the oil - no biggie, there's a whole lot worse vehicles out there for doing either; you just hafta take your time & follow the proper procedure. Same thing with taking wheels off &/or getting tires fitted - there's a whole lot worse out there for doing that too - some of which if you undo the wrong nut at the wrong time can literally kill you!! :shocked: However, I don't think that there's
anything at all on a Spyder that's quite so instantly lethal, and most of us can easily recognise when there's a need to go to the professionals for those things that could be potentially lethal eventually,
if you stuff them up or get them wrong enough (& really, a lot of the time we only go to the so called 'professionals' so that there's someone to blame if it all goes pear shaped - some of those 'professionals' won't
ever be able to do as good a job as you could yourself! :sour
but for almost everything else that you can/should be able to do yourself,
if you can actually get down low enough to work on it &/or get back up from that low once down; if you know which end of a screw driver to put in the slot & which end to turn;
if you know which end of the spanner goes over the nut & which end you push/pull on; then you are probably
MORE than capable of managing all the basic maintenance tasks on your Spyder!
hyea:
You've survived to this stage of your life without too much major trauma, haven't you? Why not trust yourself juuust a little and have a go?
Most likely, the MOST DANGEROUS thing you can do with any Spyder/Ryker is actually ryde it on the road & in traffic; are you going to avoid doing that cos you might get it wrong?? If you are, then why'n the heck did you buy one in the first place?? :gaah:
So when it comes to doing basic maintenance or fitting up some bolt/stick on Farkles &/or mods, sure, ask any questions you feel you need to, after all, the only stupid question is the one you don't ask! But as for actually having a go at the basic &/or simple maintenance items,
Just do it, you know you want to!
hyea:
And don't ever worry too much about stuffing anything up - I'm pretty sure that there'll almost
ALWAYS be someone who's stuffed up even more monumentally than you might think!! :lecturef_smilie: Do you
really need to ask me why I'm so sure about this??
pps:
