A difficult/complicated job (RTL oil change)
Is your Spyder up on three ramps? It looks level to me. What is the rear tire sitting on? I need a way to get my 2019 RTL lifted to change oil. I heard that you can't/shouldn't drive just the front wheels up on ramps.
I drive the front tires up on two ramps, and then slide a platform scissor jack under the rear at about the lower shock mount to jack it on up level.
Can't pull the rear wheel if it is run up on 3 ramps, but you can if you jack the rear level.
Half a dozen pulls on the ratchet will bring the rear up level with the front end.
