groundeffect
Registered User
I have a question.
I'm in the garage and noticed a tire is slightly below the recommend psi.
I connected a 12V air compressor to the 12V outlet in the truck, which is connected to the accessory 3-amp circuit.
With my Spyder off, the power is still going to the air compressor. Once I turned the 12V air compressor on, I heard a click, checked, and sure enough, the 3amp fuse in the front fuse box had blown. Clearly the air compressor I have pulls more then 3amps. I did check the model and documentation on it before hand, but no mention of amperage draw anywhere that I've looked.
I will be getting a replacement 3amp fuse for the one I've blown. However, I do have 5amp, 7.5amp, 10amp, 15amp, 20amp, 25amp and 30amp spare fuses here between what I have in my garage, and the spares on the backside of the cover of the front fuse box.
I DO NOT want to damage anything on my Spyder, but I was thinking of using a higher amperage fuse just to get my tire psi back up to spec.
My Question: If you temporarily use a 7.5amp, 10amp, or 15amp fuse in the accessory circuit in the front fuse box, will it damage anything on my Spyder?
Also, what determines the fuse limit on the circuits coming from the front fuse box? The size/limitation of the wires? Please advise.
Thank you.
Dean
Thank you.
Dean
