Hi, my gf Spyder originally went to the shop with a check engine code P1174, Other than that it was running fine. Code = Too lean Bank 2. She thinks she may not have had the gas tank cap on properly. After 3 weeks in the shop and many parts later it is now stalling. Changed purge valve, replaced some vacuum hoses, spark plugs, fuel filter, air filter, intake manifolds, air intake boots, o rings, intake flange. In the meantime it had codes P1171 and P1172 come up. They were going to test ride it over the next few days and if it still stalls and they suggest the next step is to replace the entire throttle body assembly which apparently is pretty pricey.
Anyone ever gone down the path of this type of Spyder with stall issues? Will replacing the throttle body assembly fix this?
The machine has less than 25,000 miles (38,000km) on it.
Any sage advice would be appreciated.
