ZDarkman
Problem: Shifter pedal is low at times, i have floorboards and occasionally I cannot get my foot between the floorboard and the shifter to upshift or downshift. Also seems harder at times to upshift at times, have to make more of an effort.
For example, I stop at light and I currently coasted to a stop in third with clutch pulled in. I attempt to downshift into second and then first. It goes into second, but the pedal is now all the way down, cannot downshift into first and cannot upshift even if I wanted to because I cannot get my foot between the floorboard and shifter. So if I start off in second, as soon as it starts rolling and I'm releasing the clutch, the pedal will move back up into the proper position. Is there a spring somewhere that assists to bring the shifter back into its normal position.
Lately I have been getting around this problem by making sure I downshift thru all the gears before coming to a stop.
I know other people have had this problem in the past but I have a hard time finding with the forum search.
1) Oil is at its proper level.
2) I have approximate 1400 miles since last oil change, have approximate 6200 miles on the spyder.
3) Linkage adjustment arm seems to be fine.
Thanks for any help.
