12 volt plug
RTVIPER
I recently unplugged both analog gauges (gas and temp). :clap: I wanted to know if it's possible to use the same connections to plug in a 12 volt outlet? If not, how difficult would it be to put a 12 volt outlet there?
Much appreciated,
RTVIPER
I wouldn't do it! These lighting side of these circuits is only 18 ga wire, and will not take much load. Tapping into the light circuits cann adversely affect other components, too. You might get by with a small load, like a GPS, that is less than 3-5 amps and fused accordingly, but it would never run heated gear or anything substantial. It could also not be used for battery charging purposes. Do it the right way and install an auxiliary fuse block or tap into the existing 12V accessory outlet circuit.
I used the positive side for the lights in the fuel gauge to energize the relay for the 12volt outlet. I then connected the outlet to the battery with an inline fuse. I replaced the temp gauge with an IPOD jack connected back to the trunk with a plug on it. This way I can plug in my IPHONE and use the gps and still listen to music.
