Results 1 to 10 of 10
    Jul 2021
    Utah
    Default Any concerns with buying a 2017 F3 with only 1200 miles?
    Considering buying a 2017 F3 with only 1200 miles on it. Should I have any concern about mechanical problems from sitting around so long without being driven much? Anything I should do right away (replace fluids, etc?)
    Thanks!
    Oct 2015
    Carson City, Nevada
    I recently bought a 2017 F3T with 1750 miles. No issues, No problems.
    Check the fluids and pressure in the tires. Ride and get to know the bike.
    Consider getting a laser alignment.
    Prepare for an oil change at 2000 miles and enjoy.
    David C
    2017 F3T
    DIY Driving/Fog Lights,
    DIY Garage Door Opener
    USB port, Battery tender cable
    Tail Rack
    May 2017
    Mesa, Arid-Zone-A
    First, Welcome to SpyderLovers! Questions I would ask: Has the bike ever been serviced after purchase? When? Has there been additives added to the fuel? Has the battery been kept on a maintainer? If not, I would expect it should need replacement. How has the bike been used? Lots of 10 mile trips or a couple bigger ones. Is the bike still covered by warranty? If so have it transferred to you.
    If it hasn't been serviced since new, that needs to be done based upon time and age. Along with replacing the original battery. I would plan on spending 6-7 hundred to have everything brought up to speed.
    Could be a sweet heart of a deal. Good luck..... Jim
    2008 Honda GL1800/California Sidecar Trike
    Platinum Silver Satin 2014 RTL, SOLD
    Semper Fi
    Active Member rjinaz86323's Avatar
    Mar 2021
    Arizona high country
    I recently (March) bought a 2018 F3L with 198 miles showing. I just finished a 3600+ mile trip with it. Not a single issue. I would say if it looks good, go for it. I would change the oil and filter right away though and just give it a thorough look over.
    Feb 2019
    Portland, Oregon
    This is pure conjecture, but for what it's worth, what I have seen on this forum, the 2017 F3L/T seem to have fewer issues than other years. At least that's been my experience with mine.
    aka: akspyderman ARtraveler's Avatar
    Have the dealer run the VIN #. That will give you the service history, if there is any. First service is recommended at 3000 miles. Based on the fact that it is a 2017 with only 1200 miles, I am guessing no initial service has not been done. Because of the time gone by, I would say the oil and filter should changed out at minimum. An overall check of the other stuff would be good also.
    If it has not been in the shop for repairs, that is a good sign. F3 is a nice ride, and if its a good one, you should be good to go.
    [SIZE=1]
    [SIZE=1]Currently Owned: 2019 F3 Limited, 2020 F3 Limited
    7 Spyders, 12 years, 175,500 miles
    Active Member ChicagoSpyder's Avatar
    Chicago
    Quote Originally Posted by Jimbob2 View Post
    Thanks!
    I'd do an oil change and a fresh battery, and then ride it like I stole it.
    2018 F3 Limited , Black/Chrome
    Active Member deer30084's Avatar
    Tallahassee, FL
    Yes. Make sure you have roadside assistance and maybe an extended warranty. My 2015 F3 broke down In May this year at 18,700 miles. The front pulley wore out. That is a common problem known to happen at 18-24,000 miles. Can-Am should have done a recall on that in my opinion, but didn't. Enjoy your new F3.
    John F.
    Tallahassee, FL
    2015 Spyder F3 SE6, black
    BRP Driver/passenger Footboards
    BRP Adjustable Passenger Backrest
    Blue Ridge Windshield
    MRA X-Creen Tour, clear, clamp-on
    H4 LED Headlights
    F3 LED Fog Light Kit, LED Amber Halo Ring Kit, LED Tail Lights, F3 Rear run/brake/turn LEDs
    Easy Brackets
    Leatherworks, Inc. 120 Special Slight Angle Saddlebags
    Custom Dynamics Front Mud Flap LED lights, Street Magic Front Fender Tips, Double Feature Lens
    2-up rear shock
    Idler pulley kit
    Jan 2017
    Vancouver, B.C.
    If you just staying in town and not going anywhere far away.
    Check the tire pressures, you need a straight air pressure tester, buy a good one.
    Jump on it a ride it.
    When you put it away at night throw the battery maintainer on it for the first little while.
    Read the manual, get used to all the buttons, i.e.: turning off the turn signals and enjoy it.
    Wash, polish it, do all the regular checks and service it this winter
    Don't overthink it.
    Cheers
    Al
    2016 F3 Spyder Limited SE6
    2005 Honda ST1300 ABS
    Jun 2011
    Near Lexington, NC
    If its been garaged, tender on battery, grab it and run. Put in some fresh oil after you've driven it a bit. My '16 F3T bought early last year with 1600mi on run like new. Zero problems.
    2016 F3T (as of 7/11/20)
    2014 RT SE (Sold Aug 16 after purchasing a Slingshot)
    2016.5 Slingshot (traded for Vanderhall fall of 2017)
    2018 Vanderhall (traded for '18 Slingshot spring of 2018)
    2018 Slingshot SLR
